Results 1 to 3 of 3
    Jul 2016
    Denmark
    Default 1,9 TDI 5 Speed to 6 speed swap CC not work 6 speed
    Hello I recently swapped my 5 speed out with a 6 speed gearbox, everything went smooth its running great. I can use cruise control on all gears but cruise control does not work when the gear is on 6? I've tried to code 6 speed in Vcds but it gave me "error 31".
    Can anyone please help or give any suggestions?
    Hi, what car are you referring ?
    If you have VCDS post a scan to se modules on car.
    BR
    Above sea-level
    You will need to program your ecu with 6-speed software
