Results 1 to 15 of 17
    hayk57's Avatar
    Default Opel Meriva B immo ECU adaptation
    I have an Opel Meriva B 1.7 with an AC DELCO E87 ECU I can't adapt new ECU to the car, I have reseted the pin many times and written new pin.
    • The ecu have the same pin as the BCM and instrument cluster
    • All vins are programmed and are similar
    • 2 keys are programmed successfully
    • I always respect security time wait about 10 minutes
    • Pin is valid
    But I always have the immo light on and the following dtcs in the ECU:
    • P0513 Immobilizer Key Incorrect
    • P0633 Immobilizer Kew Not Programmed
    I don't have immo related dtcs in other control units.
    I am working with OP-COM 2018 and AVDI official.
    I also have GDS2 and TECH2 but there isn't any ECU immo related function on them.
    I would very much appreciate if anyone would help me.
    alexandrosts's Avatar
    Feb 2017
    there where civilization started
    Hello there so you did read pin from donor ecu and reset it with abrites ?
    What was original problem to the vehicle
    Στάλθηκε από το SM-G928F μου χρησιμοποιώντας Tapatalk
    TO TUNE OR NOT TO TUNE
  3. The Following User Says Thank You to alexandrosts For This Useful Post:
    hayk57 (9th June, 2019)
    hayk57's Avatar
    Yes I reseted with donor ECU pin and adapt with new pin. They killed orignal ECU by opening it.
    Feb 2017
    Try to reset all modules and redo all immobilizer system with Opcom and keys last
  6. The Following User Says Thank You to alexandrosts For This Useful Post:
    hayk57's Avatar
    I reseted all systems many time, I also tried with SPS. Car is like starting for 2 seconds and cut, I have P0633
  8. #6
    Feb 2017
    Did you try to programme with Avdi? Seems like the issue is on the immo box. I had same problem actually I swaped ecu because was damaged with a donor programming procedure went fine but light was still on and car will start for a second and shut off my issue was the cluster I did reprogrammed cluster itself and problem solved
  9. The Following User Says Thank You to alexandrosts For This Useful Post:
  10. #7
    hayk57's Avatar
    I tried with AVDI, OPCOM, SPS.
    I rested all the modules BCM, ECU, Cluster
    Programmed again 2 keys, they are recognized and all seems good.
    Always the same I only have one DTC in ECU P0633.
    Car starts 2 seconds
  11. #8
    Feb 2017
    It starts for 2 seconds because of the immo system is enabled. Then issue must be on the donor ecu. If the car had no immo issues before is hard to have now. The question is why they open the old ecu
  12. The Following User Says Thank You to alexandrosts For This Useful Post:
  13. #9
    Feb 2017
    I do program a lot of opel and I do use same combination avdi and opcom and I have been in a lot of situations with immo,and opel immo is simple not to complicated if you don't know why they open original ecu you must find out start from there and then we go step by step
    Sent from my SM-N920T using Tapatalk
  14. The Following User Says Thank You to alexandrosts For This Useful Post:
  15. #10
    hayk57's Avatar
    I have 3 ecus, it is the same with all of them, he tell me that the ECU was dead they try to solder inside, they removed the processor ...
    it’s not usable anymore.
    I know that Opel isn’t that complicated.
    Can it be ABS related issue ?
  16. #11
    Feb 2017
    There is no immo on the abs only ecu cluster immobox and body. Probably the car had same issue before and they open ecu for no reason,so ecu will do no difference. How's your live data will it read keys when you crank?
  17. The Following User Says Thank You to alexandrosts For This Useful Post:
  18. #12
    hayk57's Avatar
    Live Immo data look good, I have to check when I crank. I read that for ACDelco E87 a Russian guy successes with IOTerminal and he had the same DTC’s.
    I don’t know if this ECU’s are really resettable ? Maybe you can’t exchange them ?
  19. #13
    Feb 2017
    https://r.tapatalk.com/shareLink?url...3&share_type=t
  20. #14
    Feb 2017
    Check this out
  21. The Following User Says Thank You to alexandrosts For This Useful Post:
  22. #15
    hayk57's Avatar
    I have already readed this topic, but my ecu don't have any flash issues. I have also updated ECU via SPS online tech2web.
    I'm beginning to have doubts if this ECUs are really resetable without IOTerminal.
