Check this file
Check this file
bekescars (10th June, 2019)
can not open, file is corrupted
Still have no file, nobody cant help ? :/
try....................
[SIZE=3][I][FONT=impact][COLOR=#ffd700]PUSH THANKS AND REP IF I HELPED YOU !!!!!!
bekescars (11th June, 2019)
I have now 2 fault - check sum error
try this if you want......i am not secure....same pass
you dont have vcds to try by obd???
I have VCDS, faults are clean but in MVB is numbers of crashed stored. I will try second file and report.
not working -- all airbags fault and one checksum
you can check and Give me Result after Test
Don't Forget press Thanks & Reputation if helped
bekescars (12th June, 2019)
Check sum error ...
with which tool you read it?
not work with xprog,not read correctly, you need to try with another tool.
