Results 1 to 4 of 4
Hybrid View
    Nov 2016
    Default Problem pressure oil
    Hello, I have such a problem, Auto is audi a3 8P 2.0 tfsi AXX, I have replaced the timing chain and the variator and after this repair while driving, the oil pressure is constantly on. Someone may have had such a problem or some suggestion what could have happened?
    Nov 2016
    I have measured the oil pressure that it is too low, but why was there no problem before replacing?
    @edit. Problem solved.
    Aug 2013
    is the solution like this one that I suggested in this post? https://www.digital-kaos.co.uk/forum...71#post2861471, or if you want you can tell how you solved ?
    Nov 2016
    sisco1, the problem with me was clogged oil filter something like soot, there was also a lot of it in the bowl, only surprised me that it happened directly after the belt and chain replacement. Well ... maybe just a coincidence ...
