Hey Guys, I got a RangeRover 2012 model in the workshop. The Vehicle had faultcodes which were showing up in the dash. Faults were ranging from Parking Brake canbus errors, TCM p0500 vehicle speed sensor and various others mostly relating to error in communication between ABS module and rest of control modules. I noticed after clearing the codes there were two codes which triggered all the rest of them..ABS wheel speed sensor Front Right and Rear Right. Client ordered all four speed sensors. I had to drill the old ones out because of rust as they were fused with the hubs. After replacement the vehicle now shows errors in Front Left and Rear Left consistently.. I swapped the sensors yet it shows the same code as soon as I accelerate the vehicle. The other codes which come up are Parking Brake and TCM vehicle speed sensor. When I check live data with my Launch X431 pro all the sensors seem to be working well yet I dont know what triggers the codes..I checked Driveshaft reluctor rings and they dont look damaged. Can it be the ABS module itself? Please help if you have any experience with this kind of problem. Thank you
