Results 1 to 7 of 7
    Jan 2014
    South Africa
    Default NEED HELP DME 7 COMPATIBLE NUMBERS
    Hi, posted an article needed help no one replied and its a common question,anyway need another assistance with a compatible dme to use on this bmw E90 ,attached is the pic .
    Thank you
    Timisoara
    Go to realoem.com input car vin go to fuel preparation select ecu and select latest part no. and all compatible no will be displayed and the cars that have the desired ecu
    Sent from my PLK-AL10 using Tapatalk
  3. The Following User Says Thank You to clauberty For This Useful Post:
    shinehead (13th June, 2019)
    Jan 2014
    South Africa
    hi, tried it but not really helping i need to compare the bosch numbers
    Timisoara
    Quote Originally Posted by shinehead View Post
    give me VIN
  6. The Following User Says Thank You to clauberty For This Useful Post:
    shinehead (14th June, 2019)
    Jan 2016
    compatible ecm list
  8. The Following User Says Thank You to Rachid69 For This Useful Post:
  9. #6
    Jan 2014
    South Africa
    Thank you ,thank you appreciate it.
  10. #7
    Jan 2014
    South Africa
    Thank u for your time ,got the numbers from one of the guys .
