Results 16 to 30 of 32
  1. #16
    Quote Originally Posted by Alekso View Post
    Radio is original from the car, it have same VIN number and there is no fault codes.
    Problem start when I try to program new key, when I try to program, incode-outcode calculation wash wrong. So I disconect battery, remuve the instrument panel and write the transponder directly in instrument. After I conect the battery, radio ask for code.
    So I start to serching for new radio, and I notice that display unit have a sticker simular to the radio with V code, I caluculate and code was OK.
    That all
    Thank you for this info.
    I guess "removing instrument panel" caused the radio anti-theft system activation and not the simple battery disconnection... very interesting, since never seen ford mk7/mk8 owners complaining that radio asks for code after battery disconnect.
  2. The Following User Says Thank You to Rdecode For This Useful Post:
    Hashim1 (26th December, 2023)
  3. #17
    Alekso's Avatar
    Also what is intersting is that when I try to program key, I was useing Avdi - incode outcode calculation fail, Smart pro also incode fail.
    Meybe the car have some other settings or software.
  4. #18
    Sep 2015
    hello to all
    code please for this
    Radio AHU 8A6T-18C815
    serial Z013375
  5. #19
    Decode Ghost's Avatar
    Aug 2015
    Quote Originally Posted by sucharek76 View Post
    hello to all
    serial Z013375
    try..........3726
  6. The Following 2 Users Say Thank You to Decode Ghost For This Useful Post:
    Hashim1 (26th December, 2023), Mankyro (24th January, 2022)
  7. #20
    shooting's Avatar
    WALES
    hello to all
    serial Z013375
    Radio Ford Wiring (digital-kaos.co.uk)
    Stick to ONE thread........
    wbr
    Don't confuse "Standing on my Shoulders" with "Treading on my Toes" ..
  8. The Following User Says Thank You to shooting For This Useful Post:
    Decode Ghost (24th January, 2022)
  9. #21
    hello to all
    serial Z013375
    Read post #7
  10. #22
    Dec 2022
    Very interesting thread. Unfortunately, I faced the issue with "blocked" Z series radio in my Ford Focus Mk3 2011r. Radio is Sony AHU, Part no: BM5T-18C815-RE and it's serial no: Z007215. After sucessfull firmware upgrade of PDM&DDM (doors modules) my vehicle started to ask for the 'Radio code'. After reading this thread I've checked the display numbers and they are: Part no: AM5T-18B955-CG, serial no: B6F00V032753. Based on J-SKy 'V' code generator, code for V032753 is 5229 (please confirm guys). I've tried to put this code but it's incorrect
    WHat's intersting, someone from Facebook told me "try code 9668" and... it works but only untill next radio power off/power on cycle. When radio is restarted it asks for code again. I have no idea why 9668 temporary unblocks my radio (it wasn't calculated based on my serials). Does anyone of you guys how can I solve this issue? Putting radio code everytime I starting my car is a little bit irritating. Maybe I should do some 'factory reset' or radio/display reprogramming? Any hints are appriacated
  11. #23
    carradio2001's Avatar
    France
    If you can try that.
    BR,
    Carradio2001.
  12. The Following 3 Users Say Thank You to carradio2001 For This Useful Post:
    076458C (4th January, 2023), Mankyro (4th January, 2023), smoggy (5th January, 2023)
  13. #24
    Dec 2022
    Which one ?
  14. #25
    irfa's Avatar
    Feb 2016
    Quote Originally Posted by Francki View Post
    Hangisi?
    6865 mate........
  15. The Following 2 Users Say Thank You to irfa For This Useful Post:
    carradio2001 (5th January, 2023), smoggy (5th January, 2023)
  16. #26
    Dec 2022
    Sorry, initially I didn't notice image with code calculated (wasn't visible on my phone). I will check the generated code in the evening and will let you know. Thanks!
  17. #27
    Dec 2022
    Hello
    @carradio2001 - thanks for you effort and for the code. Unfortunately it isn't correct. I've found on UCDS forum that this radio doesn't have any 'PIN Code' protection and problem is with FCDIM module (display module) and firmware of this module needs to be flashed (I'm almost ready to perform this operation). Issue was caused by another module update (DDM in this example) with UCDS "Update wizard". Now I know that using "Update wizard" of UCDS application isn't very safe and operation can break the FCDIM firmware. I will inform you about the results.
    Thanks for all your help guys!
  18. #28
    Dec 2022
    OK, problem finally has been fixed. As previously said, PIN code wasn't in the radio itself but in FCDIM module (main display, connected to 'radio' module). I've tried with firmware flashing/upgrading but without any result. Finally, I found that original UCDS application has option 'Disable MFD4 Keycode Security" in FCDIM tab and this solved my problem permanently. Procedure took just few seconds but the main problem was with original UCDS app Fortunately I had an access to this software. Hope that this info will save somebody's time and nervous Thanks for all your help guys
  19. #29
    kappa1's Avatar
    Apr 2013
    RO-IS
    FORD SERIAL Z Not there is in dealer Ford !
    Try code 5229 from display serial V032753
  20. #30
    can some one calculate code from serial Z155153. Part number AA6T-18C815-AD.
    Thanks in advance
