I didnt find thread for Ford Fiesta radio codes with Z,
Is it posible to find tradio code
radio code Z042832
radio code Z042832
Not coded...
kappa1 (12th June, 2019)
after battery remove its showing code _ _ _ _
0000 its not working
Hashim1 (17th March, 2024)
I try all the codes but non of them is working,
I find way how to decode the Z code radios.
On the central display I find new sticker with new V code, I just calculate the V radio code and its workingCODE 8618Thank you for the help,
Yes, but the v code sticker is on the central display.
Hashim1 (25th December, 2023)
Hashim1 (25th December, 2023), LABDANI AHMED (21st June, 2019)
The only question now is why it asked for the code, was it replacement unit?
Normally they do not require codes if installed in original car. Isn't it?
Hi this post is bullshit! because i have friend work tehnician for FORD and in 11 year him never see this model ask code !
For all FORD serial Z not exist ...
audiopoint (24th June, 2019)
Yes, you are right for control unit with Z serials no code is required, but user says there is a display unit in this audio system with V serial and it asked for the code...
The question is why it asked for the code?
The only reason is probably it is replacement unit and asks for the code if radio is installed in not original car, like it is done for Chrysler modern radios.
We just need user to confirm this.
Radio is original from the car, it have same VIN number and there is no fault codes.
Problem start when I try to program new key, when I try to program, incode-outcode calculation wash wrong. So I disconect battery, remuve the instrument panel and write the transponder directly in instrument. After I conect the battery, radio ask for code.
So I start to serching for new radio, and I notice that display unit have a sticker simular to the radio with V code, I caluculate and code was OK.
That all
