Results 1 to 15 of 20
    dd1's Avatar
    Aug 2014
    Default bmw dme mevd1724 2014 BMW4
    HI ALL, i just replaced a dme on this bmw. used, i mirrored the vin isn etc with bmw, ECU explorer. the car started fine. but give me check engine errors, fault codes. and has lose of power. idle is fine. can you guys guide me with this problem???
    rafal's Avatar
    UK - PL
    before change dme was all ok ?
    need help
    now my goal is to buy xp-005
    who will help?
    Timisoara
    You must code with e sys and after will have right vin and coding
    If you do not know how let me know, remote and one minute problem solved
    Sent from my PLK-AL10 using Tapatalk
    dd1's Avatar
    Aug 2014
    Quote Originally Posted by clauberty View Post
    Ok, I like that, give me some hints on this
    dd1's Avatar
    Aug 2014
    Quote Originally Posted by rafal View Post
    the original dme had error codes that couldn't be cleared. I transferred the vin, Isn, motor hour and checked everything again. I scanned it and it comes up with the correct vin
    Timisoara
    do you have e sys installed and e-net interface?
    Timisoara
    Quote Originally Posted by dd1 View Post
    what error codes? eeprom related?
    dd1's Avatar
    Aug 2014
    Yes and the flash files with it
    dd1's Avatar
    Aug 2014
    The original dme had waste gate codes and some other sensor related that wouldn't clear. The used one I installed I copied all the info and transferred to it. It shows the original car vin, starts but power is low when driving
    Timisoara
    then perform coding
    dd1's Avatar
    Aug 2014
    I have done some minor codings, not a dme. Any ideas how and what to do? Thank you in advance
    dd1's Avatar
    Aug 2014
    Hi, do you think you can help me out with this? I kind of tried to do it but no luck?
  13. #13
    Timisoara
    On Monday after 6
  14. #14
    dd1's Avatar
    Aug 2014
    Ok, write me here or email it so that I know, thnx
  15. #15
    dd1's Avatar
    Aug 2014
    monday has passed. anyone can help me????????
