VW POLO 9N3 2006 - do they need dealer prepared key? failed today
Results 1 to 15 of 15
    DK Veteran sdnatlst's Avatar
    Aug 2011
    England
    156
    Downloads
    4
    Uploads
    Default VW POLO 9N3 2006 - do they need dealer prepared key? failed today
    I had a spare key job today, 2006 polo 9N3 model.
    I tried with FVDI, Wizard - It autodetected CS & PIN, precoded a dealer key, but when it went to key learn, it would only learn the customers original key. So immo light kept flashing.
    When i went through again, and put 1 key required, it learnt his key and immo light went out.
    I tried it a couple of times, so locked a couple of ID48's. Im sure i also tried a blank unlocked ID48, not precoded.
    So just wondering, does it need CS prepared key on these 9n3 polo's or not? , I finished job by cloning in the end but would like to know for future.
    I also have VVDI2 but i wasnt sure if this would work on old system like this polo has?
    Tools owned -
    MVP Pro, Lonsdor, FVDI 18, VVDI PROG, VVDI2 full,
    CGDI BMW, SuperVag clone, Renault ECU tool, OBDstar X300 DP Plus
    VVDI Keytool, KeyDIY KDX2, Handy Baby
    Opcom, VCDS pro, Diagbox clone, Multiecuscan, Forscan
    Dec 2017
    7
    Downloads
    Uploads
    No just reed pin an do it with blanc transponer
    Wysłane z iPhone za pomocą Tapatalk
    Jan 2017
    5
    Downloads
    Uploads
    Had this same issue with Polo , tried several chips, blank 48, can version, EM4701, etc. and all in a sudden got a chip that did the job. No idea what the difference was , but the 1-2 issue on the instrument screen and the SAFE are gone and have 2 good keys now. Would love to know what was the trick since I had a caddy 2009 a while ago with same issue and that one has not been done (could not clone at the time, should be better covered now).
    ghostrider72's Avatar
    Jul 2012
    UK
    117
    Downloads
    Uploads
    Caddy need precoding. Different than Polo 9N
    Aug 2011
    England
    156
    Downloads
    4
    Uploads
    Very strange, im sure i tried KEY LEARN and just tried an unlocked blank 48 chip and still no luck. I guess ill try to clone these generation polo in future unless its all keys lost and im forced to try and add a TP
    Tools owned -
    p1et's Avatar
    Oct 2013
    1,133
    Downloads
    Uploads
    I use SBB for programming Polo 9N and never had problems
    Sep 2016
    18
    Downloads
    Uploads
    From my experience it is worse to have it with correct CS data precoded. Take into consideration that there is no TP2x transponder. When you have car still with you send me e2 and i make trick that will accept any id48.
  8. The Following 2 Users Say Thank You to qeso705 For This Useful Post:
    p1et (13th June, 2019),sdnatlst (13th June, 2019)
  9. #8
    super jumbe's Avatar
    Dec 2008
    Livingstone
    3,802
    Downloads
    412
    Uploads
    Why go through all that hassal when you could have clone the ID48 chip and away you go....
  10. The Following User Says Thank You to super jumbe For This Useful Post:
    godfathertre (14th June, 2019)
  11. #9
    p1et's Avatar
    Oct 2013
    1,133
    Downloads
    Uploads
    Quote Originally Posted by super jumbe View Post
    To have more knowledge and experience. By cloning you gaining no experience. If you clone then OK but next time all keys lost and we will see you asking here for help... Every monkey can clone.
  12. #10
    Aug 2011
    England
    156
    Downloads
    4
    Uploads
    I had an Audi A4 earlier that day, which i do clone because i know they can be a nightmare programming wise,
    And i had left no points on my Keytool, so i wanted to learn it
    Tools owned -
  13. #11
    Dec 2009
    scotland clydebank
    377
    Downloads
    11
    Uploads
    why waste time for later vag cloning safer faster and away to next job it amazes me wasting hours pulling pin codes when cloning 5 minutes top .
  14. #12
    Mar 2019
    Romania
    Downloads
    Uploads
    I had a sister of Polo, Ibiza 2003 1,4 diesel.
    Same issue. 2 transponders one by one works great, both programmed didn t.
  15. #13
    Dec 2010
    Nottingham
    145
    Downloads
    Uploads
    2006 on polo is a cross over year could be T6 id48 or it may have needed TP23 id48 canbus , so if left flashing it may be because you needed a canbus chip
    also depends on whether your using original chips or aftermarket , alot of the aftermarket chips get rejected by the system , yet will work on another one .
    sometimes with polo you have to wait for 30 mins with ignition on after pulling pin to code key in.
    abrites has always had issues leaving immo light flashing on alot of vag , so i assume the snide fvdi has same issue as a poor copy of it , other kit saves the day when you have the pin code . the more options you have to use the better as one succeeds where others fail and vice versa .
  16. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
    klauss78 (14th June, 2019)
  17. #14
    Sep 2016
    18
    Downloads
    Uploads
    Quote Originally Posted by rapidlocksmiths View Post
    On k-line cars was never used tp23 beside beetle and crafter at my knowledge. With proper tools live is much easier.
  18. #15
    Aug 2009
    Hampshire
    288
    Downloads
    5
    Uploads
    If i may add,my personal experience with 3 x 9N 2006 polo's , always have been the same, some T6 chip, which failed with avdi and ad100, worked with vcds with ignition on for 15 minutes @ first.
