Hi guys after read and write with kess the ecu EDC16CP34 locked and now can't communicate via obd.
I read via bdm100 the flash and eeprom and i think need reset counter to remove protection .
Please can anyone fix this problem ?
Many thanks in advance
Hi.
Upload this flash by BDM and see if your ecu come back to life.
After that repeat process to FAP and EGR off, but next time try to do it manually so the file not get focked.
Regards,
Not same version as your original but closest update, should not be a problem if you flash via BDM.
spiridonas (14th June, 2019)
you file "edc16c35 bdm flash after locked" is original, file "edc16c35 dpf egr off 1" not done correctly
if you leave the car at idle for 30 minutes, it will unlock itself
Don't forget hit thank button if i helped.
Wait with contact on for 30 min as vitaly said.
Car start?
now the ecu in bench connected in kess with 12v and CAN H L and k-line and i will waiting about 30 min to trying communication with ecu.
I tried 10 min ago but says message wake up error.
[QUOTE=morgano;Do you have also original obd read befor dpf and egr was made?.[/QUOTE]
Clone Kess?
@spiridonas
Your flash read after locking is original , no changes at all.
Chek your MCU.
But car start???
Maybe obd socket faulty.
Hmmm maybe is time to try other ecu flashed with your dumps. Seems kind of dead ecu.
Did you solder the BDSM connection or a cage and pins
