Please help me , it is urgency otherwise the car owner will kill me !!
Hello to all,
RENAULT SAFRANE (LATITUDE) 2011
the UCH cleared (virgin) by DDT4ALL , now car not detected the card and the switch not opened !!
the car has V6 2,5L engine (ECU hitachi) , UCH MC9S12XDG512 (like laguna 3)
VIN : VF1ABLABXBC241922
I red the UCH eeprom by xprog but can not find the pin code . (CWP II)
engine ECU eeprom 95640 cant too .
I went to program the virgin UCH by clone Clip but not successful.
I thing my pin code get form MVP Pro and X100pro is not OK.
Please help, I dont know how to recover the uch and program the card.
Did you read the pin code before cleaning bcm? if not, then you need to program bcm canclip via renault net.
No, I red it after clearing !!
can I do it in offline or need online programming ??
I found another dump file (Laguna) , can I use it and doing virgin (by right selection) and program ??
online programming, with counting out out code.
I can get the incode from renault dealer , then can I program it with my clone Clip ?
or need another programming process from renault ?
yes you can. You send the source code, you receive from the dealer the right one, which is valid for one hour. but you will have to handle it twice, you will also have to program the cards if there is no other equipment to write down the card
Thank you for your help ,
another question : I cant remember that I cleared the UCH by which option (Laguna III or other options),
is it important ? I am not sure about the validity of cleared file but I can connect to UCH and see the parameters .
Can I write the other eeprom file and do clearning by DDT4ALL and by right selection?
Does it work for this car or not ?
eeprom in laguna, not suitable. Many differences in bcm. write the correct file, make a virgin and program ...
how can I check it to know the eeprom file is OK or damaged ?
Solved your problem ?
