Write your donor ezs CS only
I need some help if I may ask.
I managed to make q7 alive again.
original ezs does not work. I read flash and eeprom.
I got used donor ezs with same nr and flash. I tried to write eeprom from old one, but no luck, hence I wrote virgin eeprom on it.
And voila...I have a living q7... .. with safe in cluster.
Can anyone help me copy data needed from original eeprom file to virgin one ? or.. repair original eeprom dump ?
thanks,
br,
Have a try. Pin, CS1-2 part same as your old.
Pw in pm
svrecar (18th June, 2019)
If not work, please send not virgin dump from your donor ezs
firestator (16th June, 2019)
Your virgin file seems incorrect..
Ori is OK:
vin: wauzzz4l470013176
part:4f0905852b
cs: 461211A8C2
mac: 38FA10EA
pin:34230
power class: 92
here,
donor eeprom as requested.
br,
Flash don't need to transfer, enough only eeprom. Check PM.
fabrag (17th June, 2019)
update.
DendeLT is so kind helping me, he made me several files, but no matter what I cannot make it work.It is always CP error."can not calculate component protection" so im pretty sure, my "virgin" dump is bad.
The moment I try to add data from old ezs it becomes unresponsive.With add I mean copy from original one.
Does anyone have virgin eep for 852b ezs or know how to transfer immo data to another one ?
thank you,
br,
I have transfered for you, you said you have smoke uhds, check all parts of immo data, it's same as yours ori ezs. No ignition becouse there's no programmed keys. You only need to unlock you 8e megamos and program it to your ezs, thats the all problem. If you can't unlock your key with fvdi tag key, probably you choosing bad eeprom.
Please read your ori ezs key data with tag key, put key in coil and read it. Than send it to me, I will check if key exist in your ori ezs than you probably doing something wrong
