Results 1 to 15 of 20
    Apr 2019
    Default laguna 1 2.2d non start
    hi all,
    got an old laguna that won't start anymore, no feed to stop solenoid.
    can't find a wiring diagram anywhere for this model, 1995 g8t 706, in think.
    the diagrams that i have got are 1998 onwards and show an injection computer but i don;t think this has one. also can't tell if it has immobiliser or not.
    any help would be much appreciated,
    Meat-Head's Avatar
    Sorry, just mention Laguna, has made my head spin, now feel sick and dizzy
    Look at back of diesel pump, do you see black box with 3 wires then yes going to be module
    immboliser.
    chances are at that age will be minimum of 20 rotten high resistance connections
    even if you get correct diagram it will be wrong anyway
  3. The Following User Says Thank You to Meat-Head For This Useful Post:
    Louislesinge (16th June, 2019)
    Louislesinge's Avatar
    Jun 2017
    French Jungle
    Let's illustrate it Meat-Head!
    In solenoid picture you see the black box named 4, in solenoid2 you see the simply stop solenoid named 8. In case you have simply solenoid, open the fuses and relays box near the battery and find an ignition + not cuted under starting motor and plug it on the solenoid.
    Greetings,
  5. The Following User Says Thank You to Louislesinge For This Useful Post:
    Meat-Head (16th June, 2019)
  6. #4
    Apr 2019
    i'm not at home at the minute so i can't check but iirc the pump has a normal looking solenoid and wire from it goes to an insulated bolt on the pump bracket then directly into the loom. also a couple of pots or microswitches on the pump.
    the bugger started when it came to me but after takimg the battery out to test the coolant sensors and fan switch it starts only when i put a 12v lead on the solenoid.
    the 1998 diagram i've got shows an ecu but another diagram i found on the internet shows a simple keyswitch-fuse-solenoid circuit. i suppose i am looking for something inbetween those two that probably doesn't exist
  7. The Following User Says Thank You to johnnyh33 For This Useful Post:
  8. #5
    Apr 2019
    when i jump directly to solenoid (from battery) the car starts but it seems the instrument lights come on half brightness
  9. #6
    Meat-Head's Avatar
    Think next step do full light/wiper check see what else packed up.
    can you upload photo of said solenoid, just that some times can be excess fuel
  10. #7
    Jun 2017
    French Jungle
    Quote Originally Posted by johnnyh33 View Post
    Beware not to do it when ignition is turned off cause in this state you send ignition to all the car from little solenoid wire!
  11. #8
    Apr 2019
    that is probably when i saw the dash lights half lit, when i put the cable on the solenoid and before i had turned on ignition. so maybe just a new wire from the engine fuse box will do. thanks guys. will let you knwo tomorrow.
  12. #9
    Jun 2017
    French Jungle
    Re,
    Ok, ,cut old wire first. On Renault cars + ignition should be yellow wire.
    Greetings,
  13. #10
    Apr 2019
    ok, so all the underbonnet fuses are live all the time so no good. followed the stop sol. wire back to the fuse box and it arrives at this 'general module comfort relay' in the photo below.
  14. #11
    Apr 2019
    I can't find out anything useful about this piece of shite relay module except that it does (at least) the central locking and stop sol. The manuals i've got do not have it at all and it doesn't have any way of entering a pin code (dash has no screen or anything) so i guess it enables the stop sol as long as the doors have been unlocked. but locking/unlocking doesn't help.
    i have bypassed it now and the car starts and stops but i would love to see a wiring diagram to find out what is actually going on there.
    Last edited by johnnyh33; 17th June, 2019 at 01:16 PM. Reason: left a stray word at the bottom of post
  15. #12
    Meat-Head's Avatar
    So it DID have an immobiliser in former life and it’s been hacked off
    so chances are there’s a multi plug that’s gone rotten
    you got code from vin and entered using lock unlock button
  16. The Following User Says Thank You to Meat-Head For This Useful Post:
    johnnyh33 (17th June, 2019)
  17. #13
    Apr 2019
    get code from vin? what software? another look at dialogys and it seems a code can be entered by holding down accelerator and pressing button on indicator stalk.
    hopefully don't need it now as the bypass means it is starting and stopping on the key. central lock works from internal button but not remote but i assume that didn't work before although i didn't check before.
  18. #14
    Jun 2017
    French Jungle
    Re,
    Now solenoid is without antitheft you can try to find immobox and key, just plug it and remote will work again.
    Greetings,
  19. The Following 2 Users Say Thank You to Louislesinge For This Useful Post:
    johnnyh33 (17th June, 2019), Meat-Head (17th June, 2019)
  20. #15
    Apr 2019
    there isn't a transponder ring on the ignition...i don't know shit but i reckon this might be the most basic stone-age immobiliser the world has ever seen. that's why there's no wiring diagram cos renault are a little bit ashamed of it and want it to disappear without documentary evidence once the last laguna mk 1 is scrapped (shouldn't be that long now).
