Results 1 to 4 of 4
Thread: Bmw Ecu Sync
    Dr Alex's Avatar
    Mar 2016
    Default Bmw Ecu Sync
    Hi there,is possible to synch used ecu (2nd hand) to Original Cas2 by dumps?
    Original ecu from car is tottaly damage,canīt get any data from it.i will leave both e2pīs from ecu and cas.Thanks for your help in advance!
    Car is one Bmw E60 530D with Ecu Bosch 0 281 011 224 and Cas2
    pepi's Avatar
    Write this dump to the CAS eep and sync DDE/CAS .
  3. The Following 3 Users Say Thank You to pepi For This Useful Post:
    Becoacamba (14th July, 2019), Dr Alex (15th June, 2019), Louislesinge (17th June, 2019)
    Dr Alex's Avatar
    Mar 2016
    thank you,i will test,i dont have car here atthe moment!is possible to connect cas and dde on the bench and do the sync?
    im wondering if thats possible,i will search for connections for both modules on the bench!
    Dr Alex's Avatar
    Mar 2016
    Quote Originally Posted by pepi View Post
    pepi car is running ok.thank you
