Hi guys , i need some help here
i tried to do a w212 with smok today ,
after reading and backing up the eeprom and flash file in ZGW i continue to block ezs and dash syncro
it failed the first time , and i tried blocking it again and it succeed and so i carried on to dash,
but i wasnt able to read the mileage or assyst nothing. it only showed init error and ended.
i went back to try reading ZGW also failed.
can someone tell me what kind of situation im in now ??have anyone encounter this kind of issue before as well ?
yz888 (16th June, 2019)
2008-2014
be possible to
I’m still having the same issue after disconnecting the battery and driving around. I’m unable to connect up any of the modules .
signal lights, seats adjustment, and many things are not working.
are there any other solutions to it ?
its a 2010 w212 btw .
GameTheoryOptimal (17th June, 2019), yz888 (17th June, 2019)
What programmer can I use To fix this ?
You can use Xprog-m .
xprog clone will not do the job, corrupts even more. easiest fix is dealer scn coding for like 50 quid.
