Page 1 of 2 12 LastLast
Results 1 to 15 of 17
    Mar 2019
    Default Mercedes Sprinter W906 dash
    Does anybody have a virgin flash for a 311 sprinter for the hiline model as tried to alter to correct mileage and something went wrong and now have a permanent error message showing.
    Sent from my KOB-L09 using Tapatalk
    dominik.m's Avatar
    Jun 2009
    POLAND
    You have saved ori dump?
    Mar 2019
    Quote Originally Posted by dominik.m View Post
    I do have a dash dump from it that it did with fvdi2018
    dominik.m's Avatar
    Jun 2009
    POLAND
    Are You tried to write it?
    Feb 2010
    In EEP
    What did you try to flash? W906 make ezs and cluster odb2 nothing more
  6. The Following User Says Thank You to vasa For This Useful Post:
    jomberykaso (17th June, 2019)
  7. #6
    Mar 2019
    Yes and the error is still there which is why I need a virgin dash file.
  8. #7
    Mar 2019
    Quote Originally Posted by vasa View Post
    I put a new cluster in and was changing the mileage to the correct mileage using fvdi2018 and now have the error message
  9. #8
    Feb 2010
    In EEP
    Put original dashboard back and synchronization with fvdi. Or put in donor dashboard zero and synchro with fvdi....
  10. The Following User Says Thank You to vasa For This Useful Post:
    mikajna (10th February, 2021)
  11. #9
    Mar 2019
    Tried all that with no success and not to offend but it appears you are just guessing. I posted that I needed a virgin flash for a reason
  12. #10
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    post damage dump here, maybe we can fix it
  13. #11
    Mar 2019
    Quote Originally Posted by jomberykaso View Post
    Cheers will get it done tomorrow and let you know. After researching about it I have found out it is a fault with fvdi and the w906 that they know about but don't bother fixing
  14. #12
    auto techniek's Avatar
    Mar 2017
    Do you mean fvdi 2018 can do cluster with OBD2?
  15. #13
    Feb 2010
    In EEP
    Quote Originally Posted by auto techniek View Post
    FvDI work with W906 tested many times
    Put ignition on change mileage on cluster. Ignition off and remove key.Remove EZS put mileage on 9S12. Connect ezs an switch ignition on. ON CLUSTER IS - - - - - - -. Go to FVDI menu synchronization cluster. Job done.
    Mate no need virgin flash. If you need anything, it's eeprom.
  16. The Following User Says Thank You to vasa For This Useful Post:
    auto techniek (17th June, 2019)
  17. #14
    Sep 2013
    Ssid number wrong I think
  18. The Following User Says Thank You to jomberykaso For This Useful Post:
    Dboyd2374 (19th June, 2019)
  19. #15
    Mar 2019
    Here is the new dash cluster dump, hopefully I did it right
