Results 1 to 3 of 3
    Bulgaria
    Default Audi A6 recode Component Protection!
    Hello mates,
    I have a Audi A6 (F4 Chassis) 2005 179h.p. Due to a water inside on Central convenience modul (No:46) some of module functions doesnt work properly. I replaced it with used modul, but threre is a fault code "Component protection active". Is there a possibilities to disabled it or to reprogram it. Inside in the module I found eeprom 25160. Is there a possibility to read it on circuit. Is it safety? I am using UPA-USB.
    On the bottom are the pictures.
    Jan 2016
    im not sure but if all coding info is in that eeprom.
    then you can clone info , UPA IS OK
    OR CHANGE COMPLETE EPROM ( with the original)
    Jan 2018
    eeprom
    Or use ODIS and VAS5054 to remove CP, this is the fastest way.
  4. The Following User Says Thank You to atomantmk For This Useful Post:
    airfree (18th June, 2019)
