Results 1 to 14 of 14
    Jun 2012
    Default bmw key unlock pcf7944 help
    bmw key unlock pcf7944 help pinout vvdi prog
    thx
    P&D's Avatar
    May 2010
    Don't forget to remove the battery
    Jun 2017
    At this time the only tool that claims to unlock this key is hexprog, but I tried and it failed.
    Jun 2012
    Quote Originally Posted by P&D View Post
    this new key.
    i need old key unlock, pcf7944at
    bearheroes's Avatar
    Dec 2011
    It can’t be unlocked...only way to read all data with special tools and add them to cas...
    Professional BMW immo solutions
    Macedonia is one and GREEK!!!
    Mar 2016
    Anyone done unlocking this keys? Or are they not unlockable by any tool
    Jan 2022
    only new ic pcf7944 solve in this case
    Apr 2016
    Its not unlockable only if dump avalaible can copy to another
    Oct 2015
    Tango write locked pcf7944 key in dump and it work.
  10. The Following 2 Users Say Thank You to rokibar For This Useful Post:
    castin (4th February, 2022), fuzz1 (3rd February, 2022)
  11. #10
    Sep 2020
    always read full info from 7944 then manually write in cas and all work
  12. #11
    Mar 2016
    Quote Originally Posted by bmwspec View Post
    Write in cas eeprom? Can we do it with any programmer like vvdi2, bimtool, ktp, autel etc?
  13. #12
    Dec 2020
    Do you read PCF7944 via RFID or read via wire interface?
  14. #13
    bearheroes's Avatar
    Dec 2011
    Rfid only.
  15. #14
    Dec 2020
    Just tried it out with Hitag2 v3.1 tool. Indeed I am able to read out the Remote data! So at least I would be able to program that to CAS3 in order to make Remote work.
    But how is it possible to get Hitag2 crypto (ISK Hi Lo + Psw) if you have only the key (not the CAS belonging to the key)?
