If the main SRS unit wasnt changed then you have to clear crash. Crash is stored in the main SRS unit. Read the MCU and post it here, someone will clear for you.
Hello all here, ihave in my shop a Volvo V40 , thae car had a accident , only the pedestrian airbag exploded.
The owner change the sensors and pedestrian airbag and go to Volvo to reset unit.
All ok , no faults by diagnostic only message on display that pedestrian system need service.
Somebody had this problem?
The Volvo shop say can do nothing, only change the SRS unit.
How can i read this unit , i see that xprog support this MCU is Infineon XC2361A-72F.
There is another ecu on this car only for pedestrian airbag?
fluorescent (18th June, 2019)
Have you tried cycling battery
or call Volvo hq in your country. Their product
your diagnosis scans all 2 ecu airbags ???
if the main one has no errors you should have them in the ecu pedestrians if you have a warning on the display .........
[SIZE=3][I][FONT=impact][COLOR=#ffd700]PUSH THANKS AND REP IF I HELPED YOU !!!!!!
check this zone..............
fluorescent (19th June, 2019)
For X-Prog I don't have.
I use UPA-S or CPT...
