Results 1 to 13 of 13
    fluorescent's Avatar
    Mar 2010
    ROMANIA
    Default Volvo V40 pedestrian warning on display
    Hello all here, ihave in my shop a Volvo V40 , thae car had a accident , only the pedestrian airbag exploded.
    The owner change the sensors and pedestrian airbag and go to Volvo to reset unit.
    All ok , no faults by diagnostic only message on display that pedestrian system need service.
    Somebody had this problem?
    The Volvo shop say can do nothing, only change the SRS unit.
    How can i read this unit , i see that xprog support this MCU is Infineon XC2361A-72F.
    There is another ecu on this car only for pedestrian airbag?
    ateyourv8's Avatar
    Feb 2018
    Down Yonder
    If the main SRS unit wasnt changed then you have to clear crash. Crash is stored in the main SRS unit. Read the MCU and post it here, someone will clear for you.
    mcm44's Avatar
    Nov 2009
    Poland
    Quote Originally Posted by fluorescent View Post
    No faults, because they check faults on main RCM system, which has nothing to do with PPS...
    Yes, there is second ECU, only for Pedestrian Protection System...
  4. The Following User Says Thank You to mcm44 For This Useful Post:
    fluorescent (18th June, 2019)
    Meat-Head's Avatar
    Have you tried cycling battery
    or call Volvo hq in your country. Their product
  6. The Following User Says Thank You to Meat-Head For This Useful Post:
  7. #5
    Mar 2010
    ROMANIA
    Quote Originally Posted by Meat-Head View Post
    Car was to Volvo and they pass away, they want to change half a car.
    They told owner that they reset control unit.
  8. #6
    Mar 2010
    ROMANIA
    Quote Originally Posted by mcm44 View Post
    Can you tell, please where are this ecu located?
  9. #7
    Mar 2010
    ROMANIA
    Quote Originally Posted by ateyourv8 View Post
    The main unit was reflashed on Volvo workshop, anyway i dont find any faults when i make diagnostic, also the SRS airbag light is off, only message onscreen thet pedestrian system need service.
  10. #8
    joker01's Avatar
    Jan 2018
    your diagnosis scans all 2 ecu airbags ???
    if the main one has no errors you should have them in the ecu pedestrians if you have a warning on the display .........
    [SIZE=3][I][FONT=impact][COLOR=#ffd700]PUSH THANKS AND REP IF I HELPED YOU !!!!!!
  11. The Following User Says Thank You to joker01 For This Useful Post:
  12. #9
    Mar 2010
    ROMANIA
    Quote Originally Posted by joker01 View Post
    I think so, but where is PPM located, my scanner i think is scan only one.
    I have Launch and Autocom.
    Like i say the airbag lighyt is off.
    I need to know where is the pedestrian ecu.
  13. #10
    joker01's Avatar
    Jan 2018
    check this zone..............
  14. The Following User Says Thank You to joker01 For This Useful Post:
    fluorescent (19th June, 2019)
  15. #11
    mcm44's Avatar
    Nov 2009
    Poland
    Remove passenger's compartment.
    Look up, under the dashboard, near the right pillar...
    Launch should make diagnose of PPS without problems...
  16. The Following User Says Thank You to mcm44 For This Useful Post:
  17. #12
    Mar 2010
    ROMANIA
    Thanks, i look at it today.
    Do you have xprog connections for this airbag ecu, please?
  18. #13
    mcm44's Avatar
    Nov 2009
    Poland
    For X-Prog I don't have.
    I use UPA-S or CPT...
