Results 1 to 2 of 2
    Jan 2016
    Default Ecu DDCR 1.5 kangoo problem julie emulator
    Hello guys, i have an ecu DDCR with 95080 from Kangoo 1.5 '2008 , it has BMT not UCH
    Please i need immo off , i try with julie emulator ver 97 but not working (i try with jumper 2+6 and 1+2+6)
    Any recommendation?
    Regards!
    Louislesinge's Avatar
    Jun 2017
    French Jungle
    Kangoo 2008 (or any other) with BMT never seen in my life! Remove dash and you must see the UCH left side below. Doing off with EMU will be solution like Trafic with manual switch for the CAN. Much better change the key or UCH if broken.
    Greetings,
  3. The Following 2 Users Say Thank You to Louislesinge For This Useful Post:
    chedenial (18th June, 2019), rafal (18th June, 2019)
