baze007 (1st August, 2019)
so it looks like vvdi pro with there emulated 35160 and back to school to work out manual manipulation of the dumps ......maybe time to find out how much my old enigma may cost to update hmmmm
just a thought and you probably tried it but I noticed on another forum someone said if they tried to erase the chip it failed. but if he adjusted the mileage down , as long as it was above 16km it worked ok . not sure if it does but if you haven't maybe worth just trying to reduce mileage
any update ?
Can help with cgdi erasing 35160WT
Cg-pro
Read Cas ok.
Write key ok.
Remote and immo ok!
CGDI BMW and divece sametimes work ok sametimes pc not see usb connection ....USB Device Not Recocnized....... .Pc have win7 (32bit).
Trayed with another PC (32bit/64bit) install and trable stay sametimes work sametimes not.Trayed exchange usb cable no help!
brend (12th August, 2019)
well recieved mine friday ... installed software. no instructions in english just chinese help file. tried on 4 computers always checking device , device not connected.
assumed it needed a authorisation code so sent cg a email asking.
this morning got a code ...applyed it and the same .
just tried a long shot so connected power supply from r270 to it and bingo accepted ,updated firmware and is working .
until power supply it was dead as a monty python parrot.
tried different usb cables but still wont work without power supply....hmm.
tested on various 35080s worked fine tried on a 16 dow and wont erase properly seems to leave remnants of data in first 2 lines , erase ok with r270 .
waiting for cas to test .
anyone else had a problem with having to power it up ? or did I get the faulty one?
one other thing for those who have done cas 4 5mh with these units it says to remove component and then refit after cas completed but the the ring on the pdf seems to be around 2 surface mount transistors do i remove both? just wondered
evss (13th August, 2019)
Anyone had success with Renesas V850 chips? Trying to read a 3427 and getting a "DFlash capacity mismatch" error, when the only memory option for that chip is PFlash.
<---- Coin of the Realm.
