Range rover keys
Results 1 to 9 of 9
    May 2019
    Downloads
    Uploads
    Default Range rover keys
    Hi.
    I have a 2015 Range rover sport. It's stolen recovered. I've come to program new keys to it but the eeprom data looks very wrong to me. Can anyone help please? The D,Pflash and eeprom files should be attached. If it is corrupt is it recoverable? The part number of the KVM is FK72-19H440-BF
    super jumbe's Avatar
    Livingstone
    3,934
    Downloads
    413
    Uploads
    With truecode tool all done by OBD even all keys lost....
    DK Veteran sdnatlst's Avatar
    Aug 2011
    England
    201
    Downloads
    4
    Uploads
    Quote Originally Posted by super jumbe View Post
    even after the dealer update?
    Tools owned -
    MVP Pro, Lonsdor, FVDI 18, VVDI PROG, VVDI2 full,
    CGDI BMW, SuperVag clone, Renault ECU tool, OBDstar X300 DP Plus
    VVDI Keytool, KeyDIY KDX2, Handy Baby
    Opcom, VCDS pro, Diagbox clone, Multiecuscan, Forscan
    Livingstone
    3,934
    Downloads
    413
    Uploads
    What deferent this will make when pin codes and key numbers remain the same otherwise all your 2nd key will not work.
    scotland clydebank
    407
    Downloads
    11
    Uploads
    has anybody done this all keys lost with truecode for range rover 2015 with the protected KVM on if so will buy the modules i just emailed
    Chris to double check this
    works and will not damage car .
    Aug 2015
    Spain
    19
    Downloads
    6
    Uploads
    Quote Originally Posted by godfathertre View Post
    has anybody done this all keys lost with truecode for range rover 2015 on if so will buy the modules i just emailed Chris to double check this .
    I think that even with Truecode to make the key, you have to dismantle the KVM module, I have tried several key programming machines and none has worked well if it is not demontando the module of the car. I think that the manufacturers of those machines like Truecode and JLR Doctor of Keyprogtools are interested in publicizing that they are doing it by OBD and when a car of more than 2015 comes with the protected KVM, they do not work by OBD
    Mar 2009
    40
    Downloads
    19
    Uploads
    No aftermarket tool will do the protected KVM. The protection is the removal of the add key routine from the KVM firmware. So unless you know of a tool which flashes the KVM to put the add key routine back into the kvm you are not going to find one.
    The dealer tool allows adding of keys only when new kvm is fitted and going through the module initialisation. Once fitted and initialised, no more keys can be added.
  8. The Following User Says Thank You to madaxe For This Useful Post:
    godfathertre (21st June, 2019)
    scotland clydebank
    407
    Downloads
    11
    Uploads
    how do you check if car has protected kvm firmware before add key or lost keys any tool that can read these with no corrupt car .
  10. #9
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
    670
    Downloads
    155
    Uploads
    4
    truecode has killed loads of cars in the past
    what makes you think it is safer than any other tool???
