Results 1 to 9 of 9
    May 2019
    Default Range rover keys
    Hi.
    I have a 2015 Range rover sport. It's stolen recovered. I've come to program new keys to it but the eeprom data looks very wrong to me. Can anyone help please? The D,Pflash and eeprom files should be attached. If it is corrupt is it recoverable? The part number of the KVM is FK72-19H440-BF
    super jumbe's Avatar
    Dec 2008
    Livingstone
    With truecode tool all done by OBD even all keys lost....
    sdnatlst's Avatar
    Aug 2011
    England
    Quote Originally Posted by super jumbe View Post
    even after the dealer update?
    Tools owned -
    AD100 PRO, Lonsdor, FVDI 18, FVDI 20, VVDI PROG, VVDI2, VVDI MB
    CGDI BMW, SuperVag, Renault ECU tool, OBDstar X300 DP Plus, AUTEL im508
    VVDI Mini Keytool, KeyDIY KDX2, SBB, ACDP CAS/KVM
    Opcom, VCDS pro, Diagbox, Multiecuscan, Forscan, JLR SDD
    Dec 2008
    Livingstone
    What deferent this will make when pin codes and key numbers remain the same otherwise all your 2nd key will not work.
    Dec 2009
    scotland clydebank
    has anybody done this all keys lost with truecode for range rover 2015 with the protected KVM on if so will buy the modules i just emailed
    Chris to double check this
    works and will not damage car .
    Aug 2015
    Spain
    Quote Originally Posted by godfathertre View Post
    has anybody done this all keys lost with truecode for range rover 2015 on if so will buy the modules i just emailed Chris to double check this .
    I think that even with Truecode to make the key, you have to dismantle the KVM module, I have tried several key programming machines and none has worked well if it is not demontando the module of the car. I think that the manufacturers of those machines like Truecode and JLR Doctor of Keyprogtools are interested in publicizing that they are doing it by OBD and when a car of more than 2015 comes with the protected KVM, they do not work by OBD
    Mar 2009
    No aftermarket tool will do the protected KVM. The protection is the removal of the add key routine from the KVM firmware. So unless you know of a tool which flashes the KVM to put the add key routine back into the kvm you are not going to find one.
    The dealer tool allows adding of keys only when new kvm is fitted and going through the module initialisation. Once fitted and initialised, no more keys can be added.
  8. The Following User Says Thank You to madaxe For This Useful Post:
    godfathertre (21st June, 2019)
  9. #8
    Dec 2009
    scotland clydebank
    how do you check if car has protected kvm firmware before add key or lost keys any tool that can read these with no corrupt car .
  10. #9
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
    truecode has killed loads of cars in the past
    what makes you think it is safer than any other tool???
