Results 1 to 8 of 8
    DK Veteran FIRAS72's Avatar
    Jun 2013
    Default VW Passat B8 ELV problem P160A
    hello
    have problem whit passat 2017 whit elv check sum error P160A a need repair dump
    3Q0 905 861
    HW:H05
    SW:0032
    KriptoKey's Avatar
    Feb 2012
    For this problem I suggest looking for a virgin file or a new ELV and programming it using the vehicle's PIN code, you can do it with any scanner or abrites
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Jul 2009
    Far far away
    On MQB there is no pin code.
    Hoever your MCU is locked so is read crypted by Multiprog.
    4C7570755F73616E64755F696D6D6F5F736F6C7574696F6E73
    Jun 2013
    i try to read it with vvdi prog
    Jun 2014
    Quote Originally Posted by FIRAS72 View Post
    try flash the elv by E-odis offline maybe rework, cause the immo info' looks are OK...
    Jun 2013
    Quote Originally Posted by pouleddy View Post
    i try it but same error any ather help
    Romania
    here you have, pass in pm
  8. The Following 2 Users Say Thank You to ghitab For This Useful Post:
    FIRAS72 (10th March, 2025), lupu_sandu (10th March, 2025)
  9. #8
    Jun 2013
    Quote Originally Posted by ghitab View Post
    thanks for help it work perfect
