read cas....then mileage to 0 km
read dash...then put your mileage desired
Or load dash and cas eeprom for set new km.
Itumeleng (18th June, 2019)
Okay, CAS I can read but dash which one? Top of steering or centre? And which eeprom is there?
Sent from my HUAWEI CAN-L12 using Tapatalk
brane0001 (7th May, 2020), Chupsy (29th December, 2020), Itumeleng (18th June, 2019), rtbdiagnostic (19th June, 2019), Yhoni (19th April, 2021)
Thanks Brend, will get on it tomorrow and report back
Got it right! Much appreciated guys.
Hi, only in CAS and dash are stored the mileage? In dash what eeprom is, can be read in-circuit? To write i need to replace the eeprom or i can use the same? Thanks
Dash has a 35080 inside, you need a good programmer to do the job.
christensen (13th July, 2019)
M35080 Programmer is good for this kind of eeprom. (The red one programmer)
For this job I always replace dash eeprom for a new one with mileage edited.
christensen (13th July, 2019), neksus (18th December, 2020), sagie1zn (30th July, 2019)
Thanks guys! I have UPA 1.2, TL866A, Carprog V9.31, FDVI, X-PROG-M V5.0
Carprog can erase km on 35080 than you can write new km. If it is 35080vp you need better tool to erase.
christensen (15th July, 2019)
HI WOULD UPA 1.5 WORK FOR MINI COOPER MILEAGE>? TO READ CAS AND DASH CLUSTER?
brend (31st July, 2019), donchester (31st July, 2019), jomberykaso (30th July, 2019)
ok thank you
