Results 1 to 4 of 4
    McDowell's Avatar
    Feb 2019
    Zamunda
    Default Nissan Micra BCM Rear fog light problem
    Hello mates,
    I have a micra with what I think is a typical issue. Rear fog light is not switching off even if you take off the key, do you have inofrmation wiring diagrams or something for reaserching? i am pretty sure it miust be a bad relay but i do not know which one.
    Thanks a lot in advance
    Meat-Head's Avatar
    ON TOPIC:-
    VAUGE MODE ON:-
    in the middle of the plug is a red or green wire THINK AND ONLY A THINK
    in middle of board is a transistor in the middle of a silver square, that’s it
    VAGUE MODE OFF:-
    just swap the 95080,95160,93C66 whatever eeprom to a used on.
  3. The Following User Says Thank You to Meat-Head For This Useful Post:
    McDowell (20th June, 2019)
    Meat-Head's Avatar
    ON TOPIC:-
    remembered now, after a sleep
    had a juke in no rear fog, was plug in n/s trunk unplugged, came out the bcm thigh white plug “in the middle “
    green wire turns to red.
    then had a micra with whatever bcm fault fitted used bsi and rear fog played up
    sure was the same as the juke.
    if you suspect relay hit each one with screwdriver see if hoes off.
    as for that transistor in square, CAREFULLY poke pins see if for interior light
  5. The Following User Says Thank You to Meat-Head For This Useful Post:
  6. #4
    McDowell's Avatar
    Feb 2019
    Zamunda
    Thank you very much for your answer, i think I´m going for vague mode XD...they are very cheap second hand...
    ON TOPIC:-
    VAUGE MODE ON:-
    VAGUE MODE OFF:-
  7. The Following User Says Thank You to McDowell For This Useful Post:
    Meat-Head (20th June, 2019)
