    Sep 2013
    Default newbie help xprog
    hi guys anyone clued up on using xprog
    i have this dash and need to know what wires on the xprog to use to connect to the dash speedo conection points 2.JPG65165912_414095099179617_1426064266238099456_n.jpg
    i have been searching for a while now and im kind of stuck
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    check in your package...
    you need to find 9S12 adapter...
    put adapter on xprog box clone...
    choose in SW 9s12 the right one...
    read...
    change dump with a dash SW...
    or post it that someone helps you...
    write...
    donīt forget to take money from customer...
    by the way... you are alsmost 6 years member and only 3 posts... WOW...
    When I help you press Thanks and Reputation
  3. The Following User Says Thank You to figani For This Useful Post:
    B0dge (19th June, 2019)
    Sep 2013
    Quote Originally Posted by figani View Post
    read...
    write...
    i know i tried to register last week and it said email already known then i remembered i cam on years ago to have a look.
    i have selected correct sw but i get error access violation xprog shows green light then i get device silent with red light 64675501_335681633992639_579836386144681984_n.jpg64652470_1308396295980078_6434382774920019968_n.jpg64989646_2398038293777150_5760367338046095360_n.jpg65001186_443218496477893_3935124890012614656_n.jpg
    Sep 2013
    ok ive sorted that i think it was a driver problem now i get cant access bdm check connection
    figani's Avatar
    Feb 2018
    I wrote you all...
    Check again my second and third sentence...
    When I help you press Thanks AND Reputation...
  7. The Following User Says Thank You to figani For This Useful Post:
  8. #6
    Sep 2013
    I wrote you all...
    reading now, thanks again
