Results 1 to 7 of 7
    Nov 2015
    Default MC9S12HZ256CAL 3L16Y odometer correction
    I need to read a MC9S12HZ256CAL 3L16Y mcu via Xprog where do I connect? To the bdm port or directly to the mcu pin? Anybody has the correct pinout to use?
    Many thanks
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    What car is?
    What model is?
    What year is?
  3. The Following User Says Thank You to jomberykaso For This Useful Post:
    sagie1zn (21st September, 2019)
    Nov 2015
    Quote Originally Posted by jomberykaso View Post
    What car is?
    What model is?
    What year is?
    It is a Lotus Elise 1.6 2011
    Sep 2013
    Good Luck!
  6. The Following User Says Thank You to jomberykaso For This Useful Post:
    ilDandi (19th June, 2019)
    I have no connection with this pinout with my xprog. I connected with different programmer but need info about milage location
    thx
  8. #6
    Nov 2015
    Well, I'm here after two years with the same issue
    I read two different cluster one with 35034km and the other with 43445km
    I found that the mileage is stored at 000122
    But in the lower mileage one it is repeated in several other addresses
    If I modify all those addresses with the mileage I want I get 000000km on the cluster
    What am I missing?
  9. #7
    Feb 2022
    The cluster probably saves the mileage at a fixed interval, for example every 5 second into a ring buffer. The lower mileage the cluster was probably power up enough long to fill the ring buffer with the last known mileage.
    You are probably missing a CRC. The cluster detects altered data and ignore them.
    Have you a dump of the program section of your cluster for disassembly purpose? The mileage could be set through OBD port normally.
