Results 1 to 7 of 7
    rex89's Avatar
    Not Near Tricore MCU
    Default Smart key no Ignition Toyoa land cruiser VX year 2008
    Hello Guys ,
    Please i need help on an toyota land cruiser Vx year 2008 petrol engine V8
    smart key stop to work after batt discharge , key stop to turn ignition to on but remote work well
    i check all fuse a diagram according some fault codes(B2784-Antenna Coil Open/Short and B278A Immobiliser Power CHarge Malfunction(VC5 GND Short) that i find into immobiliser but all fuse and wiring seem ok , i read ID code box and smart ID , i loaded 93XX86B smartkey box into tango key stay into dump but i dont trust in ID code box dump(93XX46B) seem corrupt thanks for any help and suggestions.
    Best regards
    Imagination is more important than knowledge, because knowledge is limited ... while imagination creates the world.
    rex89's Avatar
    Hello guys,
    Please is it possible to get another dump of ECU ID CODE already reset for get ignition and try to program key
    thanks.
    BR
    Oct 2015
    what about the orange light on the push button ?
    rex89's Avatar
    orange light not work i try to change push button always same
    Oct 2015
    the problem is with the power control ic found in smart aggregation but try with this reseted dump report the result
  6. The Following User Says Thank You to Tedum For This Useful Post:
    rex89 (20th June, 2019)
    rex89's Avatar
    OK thanks i will try and post result tomorrow thanks for files
    Jul 2023
    Hi tedum, I have same problem. My vehicle had slight water damage. All wiring tests ok. Should I try new ecm?
