Results 1 to 1 of 1
    Jun 2018
    Egypt, Alexandria
    Default Quick guide for Purchasing an OBD Tool Based on needs.
    Hello Everyone !
    So, I really was thrilled to post about this particular one a long while ago but was hindered because of my studies and finally found leisure to tell You a little about it, here We go !
    All I am about to say in brief is just from my own point of view and based on people expertises with these specific pieces of Hardware/Manufacturers I'll talk about below in the business of DTC (Diagnostics of Trouble Codes) for Auto, just for the sake of making up Your own mind and picking the right choice depending on Your needs before purchasing any of those out in the market, no matter You're a DIYer, Auto trader or skilled/beginner mechanic or technician, hence I'll have these tools categorized under 3 levels (DIYer, Intermediate and Professional/Expert).
    1- Beginner/DIYer:
    If You were to be of those looking for functionality and a budget Tool that will reliably do the job as it really should then I'd recommend these three to consider for the first place with exception for the (AL319) as both of the other two doesn't only cover the basics like scanning obd codes or reading live data, but also covering the other Equipment systems like: SRS, Airbags besides the wide makes coverage.
    1- BlueDriver Bluetooth Professional: https://ebay.to/2lVBPay
    2- Autel AL619: https://ebay.to/2lVCbxU
    3- Autel AL319: https://ebay.to/2x6HJbt
    4- Launch CRP129: https://ebay.to/2ZHueMa
    2- Intermediate:
    For this one We are gonna go a little higher for budget and consequently the capabilities as the ones We're discussing are way more advanced on both hardware and software sides for they include special functions feature such as Immo key programming, Throttle adapting, SAS Adapting, service indicators reset (Oil,brakes...etc), coding and programming of sensors in some of these tools and much more features to find out in addition to accessories and adapters included with some of These tools like Launch X431 Pros Mini.
    1- Launch X431 Pros Mini: https://ebay.to/2GBllLm
    2- Launch X431 ICarScan: https://ebay.to/2jYQ5Pc
    3- Autel MK808TS: https://ebay.to/2Vx3K0O
    3- Professional/Expert:
    Last but not least, and for this division I'd like to declare that it's only dedicated to those of either specialized in fixing the ECUs by performing Reflashing/Reprogramming using J2534 Pass-Thru Protocol Based Tools besides each manufacturers software that comes from the technical section of each of those in case of needed or for running crucial, comprehensive and precise diagnosis, hence You shouldn't be shocked of the cost of these tools and so is the affordability !
    these tools also include all of the features mentioned in the intermediate section above, yet they come with even higher Hardware and Software Specs to make it way even more convenient and reliable when using besides the wide Manufaturers coverage Worldwidely.
    1- Autel MK908P: https://ebay.to/2kvHkMT
    2- Autel MK908: https://ebay.to/2GLuLEa
    3- Autel MS908P Elite: https://ebay.to/2kwoSnm
    4- Autel MS906BT: https://ebay.to/2GRlPyE
    I hope that You get something from what I've mentioned above, Cheers !
  2. The Following User Says Thank You to Belalmondeo For This Useful Post:
    rotnis (21st April, 2022)
