    Sep 2013
    Default Adding Key to VW Passat B7 2012
    I have VW Passat B7 2012 with kessy and ID46 transponder.
    I have FVDI2 and SVDI2 but I cannot see Passat B7 listed in key learning options.
    Both FVDI2 and SVDI2 detect car as Passat B6/CC and waits for 10 min to read CS and PIN from ECU but fails giving error 'Cannot detect motor type'.
    My ECU EDC17C46 and I have working key. Please suggest how to add 1 more key.
    SVDI is able to read dash, attached is the screenshot of the same. Can this be used?
    Apr 2016
    uk
    Quote Originally Posted by abdulk79 View Post
    On Passat you do not have immo data in the cluster
    Take out CCM and read 95320 eep
    Make dealer key and learn it.
    rola1971's Avatar
    Jun 2014
    Dublin
    you need read 95320 from cofort module and after make dealer key, but dont add
    need learning used vcds or vvdi2 or fvdi
    good luck
    Sep 2013
    Thanks Buddy.
    Once I get CS and PIN from DUMP, can I use SVDI/FVDI to make dealer key and learn key?
    Sep 2013
    Thanks Buddy.
    Got dump from comfort module and post that it was cake walk using SVDI.
    Thank you all for your help
    Sep 2013
    How do I lock the new key? It shows as dealer key but in lock status it says 'No'
