Hello everybody,
Can someone help me about a alfa 147 1.9 JTD -2002.
It seems that a copy of the mileage is in the Euro 3 box. That?s why I opened the ignition box Bosch but I don?t know which chip is the one to program. The numbers written on them don?t mean anything for me. I?m supposed to search a 95p08.
Here are the pictures if someone knows that.
Thanks for your help.
ignition box references
Yfrog - jtdeuro3010p - Uploaded by dragonsnet
Thanks a lot for your help.
I didn?t turn it over (but I will if you think so) because I have the picture found in the manual of the tacho universal and it didn?t seem like it at all. That?s why I was wondering if it was the right model box. On the chip on my box, it is written :
AD22057 R0129 J46232
iB59458 R4839 L114FKM
B575 17 a4u
B5817 6T CD43
14DT M 904 M
3029032 118121
It doesn?t mean anything for me.
I found this box outside near the motor.
On the other side of the box, there are condensators, plugs ? maybe the 5p08 is in this face, like you think.
Yes, rigth.
I hope these documents can help you find the 95p08.
read and post dump.
Regards.
Thanks a lot.
I will use this picture in order to find the right chip. On the board, it's the one where we see the least what is written on it.
I have read this dump with upa.
I want to modify it to 187 498 kms. Or maybe I have only to modify it to 00 kms, erase it ?
The problem is that I don?t succeed to find again the mileage. It is either 230205 kms or either 237703, because the car has worked since the correction of the dash. I don?t know how it increments or stays at the old value.
More over, I have no mean to verify it after the correction with the new dump. Do you know a mean ? Do you know how it works on this car ?
Try this one and report back
Do you succeed to read the old mileage in the old dump ?
I read 232 965 from the old dump (like you, no ?). I don?t know if it?s correct because the difference is a bit too much, no ?
In order to test it, I wii be able to say if the car starts only. I could not read the mileage with the fiat tool.
Old value was 232980 is that close enough?
Thanks. I dont' know if it is close enough. It seems strange to me, so much kilometers. I wanted to be sure because I don't have any mean to test it after replacing it in the car. I won't be able to test it. Thanks.
Do you think that the mileage difference between the dash and the ecu of 2775 or 4738 kms is possible or false ?
the eeprom on that car is in the tacho and the eeprom its a 93s86 send me the dump and the km that you want to put and i send you the dump alreadi done
