Ok. No one answered me so i took a shot in the dark...
Results are as follows for now:
1. CarProg - with A10 adapter - Four wires (BKGD, GND, RESET and Vdd) - Reading of both EEPROMs successful - You just need to select appropriate MCU and it's OK. as in second picture form previous post
2. Xprog - Four wires (BKGD - B3, GND - GND, Vdd - Vcc, RESET - B5) without bdm adapter, selected 9s12 unsecured - Nothin - BDM communication error - as in first picture from previous post
3. Xprog - 7 wires with BDM adapter (BKGD, GND, Vdd, GND, GND and EXTAL twisted together and XCLKS) 9s12 secured - as in pictures - Reading both EEPROM and FLASH successful from one MCU. Two GND's are used, one is from bottom left on bdm adapter and second is accros XTAL pin. That second one after it's twisted with EXTAL wire for like 12cm ends in same point as first GND on board - on picture pin "2"
Now problem is i can read only right one. When i move XTAL an XCLKS on left one Xprog just hangs on "bypass security" If i put all pins on left side of the left chip (mirrored pins) same happens. I'm really new at this and only thing i didn't try is to lift XTAL pin of left chip as mentioned in Xprog diagrams. Now, i don't own hot air solder so it's difficult for me to do it. My question is if i remove resistor on board where is XTAL connection wouldn't be the same as i would lift pin on chip? I think it's fairly easier to do this.
