Results 1 to 10 of 10
    Aug 2009
    Default Volvo V50 CEM read with XPROG
    Bit of help needed...
    I need to read EEPROM and Flash from both MCU's in 2004 Volvo V50 CEM (In my case they are 9S12DG256B and 9S12DT128). I've read the EEPROM from both with CarProg and A10 adapter from 4 pins on board. But, off course with CarProg i can do only that.
    However i came across site that says i can read them from same point on board with Xprog. Finally, iv'e got Xprog (clone) and before i connect to the board i can see that with Xprog you can't select specific MCU just the family and Xprog automatically recognize it and reads it (flash or eeprom as you select).
    Now my question is will Xprog find only one MCU from this point on board or both and do i need to find another point. As i see it on my board there is two same points on board. One from i've read it with carprog and it's the same point found in picture from website. And another same five-point infront of another MCU. In picture i can see that, if i've got the pins right first point is indeed BKGD and it would be much easier to read it from that point as i don't have good solder skills or hot air solder.
    This is picture from instruction website as stated as xprog connection:
    This is CarProg connection of my board where i successfully read both EEPROMs
    And if get this right this is another possible connection infront of another chip, and it should be OK.
    Please correct me if i'm wrong. I'm very new at this.
    Aug 2009
    Ok. No one answered me so i took a shot in the dark...
    Results are as follows for now:
    1. CarProg - with A10 adapter - Four wires (BKGD, GND, RESET and Vdd) - Reading of both EEPROMs successful - You just need to select appropriate MCU and it's OK. as in second picture form previous post
    2. Xprog - Four wires (BKGD - B3, GND - GND, Vdd - Vcc, RESET - B5) without bdm adapter, selected 9s12 unsecured - Nothin - BDM communication error - as in first picture from previous post
    3. Xprog - 7 wires with BDM adapter (BKGD, GND, Vdd, GND, GND and EXTAL twisted together and XCLKS) 9s12 secured - as in pictures - Reading both EEPROM and FLASH successful from one MCU. Two GND's are used, one is from bottom left on bdm adapter and second is accros XTAL pin. That second one after it's twisted with EXTAL wire for like 12cm ends in same point as first GND on board - on picture pin "2"
    Now problem is i can read only right one. When i move XTAL an XCLKS on left one Xprog just hangs on "bypass security" If i put all pins on left side of the left chip (mirrored pins) same happens. I'm really new at this and only thing i didn't try is to lift XTAL pin of left chip as mentioned in Xprog diagrams. Now, i don't own hot air solder so it's difficult for me to do it. My question is if i remove resistor on board where is XTAL connection wouldn't be the same as i would lift pin on chip? I think it's fairly easier to do this.
  3. The Following 2 Users Say Thank You to thugsoul For This Useful Post:
    fezo500 (12th December, 2020), mexanico1971 (30th June, 2019)
    Jul 2015
    left proccesor is without securety so you must chose unsecured
  5. The Following User Says Thank You to oskars268 For This Useful Post:
    thugsoul (30th June, 2019)
  6. #4
    Aug 2009
    Never thought of that. So 4 wires only. And connections on board left of them? I see that first from top to bottom is BKGD but i cant trace for sure others. Becuase i'm pretty sure i've tried it from four pioints between them and with unsecured option.
  7. #5
    Aug 2009
    Alright
    I've managed to read both EEPROMs and flash from both MCU's
    Turns out both MCU's are indeed secured, contrary to oskar268 suggestion. I did it right the first time, just that my soldering skills are nonexistent to be fair. Just took another shot after failed attempt to read it unsecured with 4 wires without BDM adapter.
    So to help others, just follow XProg attached wiring diagram -> Device -> Type - MCU/MPU -> Subtype - Freescale HC(S)12-secured -> Device - MC9S12 - EEPROM/FLASH - secured
    On connection diagram in this case is 112-PIN LQFP (except MC9S12H256) - on many tutorials there were attached diagrams for 80-PIN and other misleading infos.
    Use BDM adapter and from it connect like in the picture. From every MCU there are mirrored connections just left from it and under it.
    Now... question remains. Is it safe to write on this MCU's with XProg clone?
  8. The Following 6 Users Say Thank You to thugsoul For This Useful Post:
    datapage (20th June, 2023), Edwarth (23rd June, 2020), erikanperkan (9th March, 2020), faze (31st March, 2022), fezo500 (12th December, 2020), Pirate08 (17th January, 2022)
  9. #6
    May 2010
    thanks for info
  10. #7
    Apr 2013
    United Kingdom
    hi can you post flash please? Thanks
    Hit like and thanks if I've helped you!!
  11. #8
    Aug 2009
    Here you are
    EEProm from both MCUs and Flash.
  12. #9
    Apr 2021
    Can I have the picture of carprog diagram please
  13. #10
    ricked's Avatar
    Apr 2016
    Europe
    Both MCU's are with out lock Bit, lock bit is FE, means not secured, 0x00FBF0F
  14. The Following User Says Thank You to ricked For This Useful Post:
    PierreTheron (4th October, 2022)
