try and comment please.
glenchafe (23rd June, 2019)
tried file but comes up with internal failure codes , incompatibility with soft ware , I think module its self is faulty so I cant let you know if file is good , I am thinking it is and module is no good itself, thanks
just tried file in another module I have same result
and if you take the file from the other module, does it work?
I have been so boggled because I have been taking module in and out so many times I am not sure where I am now but I will try to redo the file from second module and install and report back
OK perfect thank you.
this is second module crash data maybe if clear it may work
could someone please help clear this second file
glenchafe (26th June, 2019)
glenchafe (24th June, 2019)
14 codes including crash full and locked code , won’t clear tried autel and IDS
Same thing I have tried writing numerous files in 3 different 17 modules tried new chip in one tried two other crashed modules fixed the files each one had first then tried other files but end result every time I end up with 12-14 codes that won’t clear out with autel or ids and one of the codes is crash stored full and locked . Does anyone have a good know file tested good they can help me out with I try this one last attempt .
I tried all flles including one I cleared using ast only file got to work is this one tested perfect
Hi friends i have the same problem , this file working good? if yes can u give me password?
