Results 1 to 7 of 7
Thread: Astra J Problem
    Mar 2018
    UK
    Default Astra J Problem
    Astra J 2010 1.6 petrol automatic - AKL - added key OK but engine wont crank (central lock working from remote)
    the car was a long time with flat battery
    Diagnostic can't connect to ECU - error U0100 - ECU communication faulty
    Maybe ECU is falty maybe wirings - If I put ECU from other car without immo off - Can I connect diagnostic to ECU to check that wirings are OK?
    Feb 2015
    Italy
    Yes, u can for sure but wont crank anyway
  3. The Following User Says Thank You to gabrilupo For This Useful Post:
    Manta1600 (27th June, 2019)
    Mar 2018
    UK
    Quote Originally Posted by gabrilupo View Post
    If the problem is ECU which oder parts must swap
    - Dash
    - BCM
    Apr 2019
    manchester
    have you done it by obd and have you cleared the faults from the restraints and column unit
  6. The Following User Says Thank You to keygargoil1 For This Useful Post:
    Manta1600 (28th June, 2019)
    Mar 2018
    UK
    I erased all possible error codes - with autocom and opcom
    U0100 is permanent
    I Will try with ECU from other just to check is it wires problem or ECU problem
  8. #6
    Mar 2018
    UK
    Today I found out why I can't see the Engine ECU
    It's missing (stolen) the Automatic Gearbox ECU and this interrupts CAN connection to the Engine ECU
    I think that if I connect CAN wires I will have connection with the ECU and the engine will work
    Tomorrow I will try
  9. #7
    Mar 2018
    UK
    Today I connected the CAN line and was able to conect to the engine ECU
    after that engine still doesn't crank because there isn't signal for parking position from gearbox ECU
    then I connected the starter manually with wire to +12 on the battery and the engine sterted from first time
    Now must find ECU for the gearbox
