Results 1 to 2 of 2
    Sep 2018
    Croatia
    Default KTag 7.020 clone, checksum error on 99%, Bosch ME7.9.10
    Hello
    I get checksum error at the end of reading the ECU, I tried to install C++ libaries(2005, 2008, 2010, 2019) but no luck.
    Can I fix this somehow?
    Thank you
    P.S.
    Car is Alfa Romeo Mito 1.4TB 155hp
    ECU is Bosch ME7.9.10 as I stated in the title
    Sep 2018
    Croatia
    SOLVED!!!!
    I hope this will help other people
    So I installed k-suite 2.25 which can be found here
    http://blog.uobdii.com/ktag-v2-25-fw...-installation/
    I copied "help" from k-suite 2.23 to 2.25 folder and reinstaled c++ libaries AGAIN which can be found at 2.25folder under drivers and it is called vcredist x86 there and abrakadabra it worked
    Read with k-suite 2.25 and reinstalled vcredist with no problem
  3. The Following 5 Users Say Thank You to MartinF1 For This Useful Post:
    AIDIN R O (7th January, 2020), g5n14 (29th June, 2019), moky (29th June, 2019), pulsar2000 (5th November, 2022), speedy100 (14th February, 2022)
