I need to know what kind of capacitor i have on the board which i marked with yellow arrow.
Please help.
Please help.
hi mate,
It is capacitor. You can change it by other same colour and size.
I hope help you![]()
mihaylov80 (29th June, 2019), rtbdiagnostic (8th July, 2019)
first of all that is a capacitor
next question?
ah, thanks,
is this a Ceramic Multilayer SMD Capacitor and if so, what Farads it should be , i need to purchase the same.
just put same size. This worked for me always.
McDowell (3rd July, 2019), mihaylov80 (29th June, 2019)
measure the red marked
To measure the farads you need to disconnect one leg, probably nano farad.
Meat-Head (8th November, 2019), mihaylov80 (29th June, 2019)
isn't a true the more the better meaning farads?
QUOTE=autotrans;3611817]To measure the farads you need to disconnect one leg, probably nano farad.[/QUOTE]
Not always the case, but if it is a ceramic capacitor probably won't hurt.
mihaylov80 (30th June, 2019)
good day need some advice - replaced screen on a digiprog 3 and damaged multilayer ceramic capacitor see image component C71 need the value of the correct replacement i.e. datasheet parameters the temperature coefficient and voltage rating or any other way to determine the value of this multi layer ceramic capacitor suggestions be appreciated
'If I helped, please click Thanks +Reputation..!'
For a smd ceramic temperature coefficient is probably not important, as a general rule of thumb voltage rating is double the circuit
voltage ie 5v = 10v \ 12v = 24v or the next value up. the awkward one is the value in farads.
