Results 1 to 7 of 7
    Fec001's Avatar
    Default W164 EDC16CP31 DPF off problem
    Hi!
    I need help with this car. We did many things to stop regeneration but nothing worked. Please check my file and if someone find solution, I ready to pay
    Car is always started to regen when coolant reach 50C. Idle consumption raise to 5,9l/h and smoking white very hard and smelly.
    unnamed11112007's Avatar
    Aug 2015
    Belarus Molodechno
    mod for you with only dpf off
    --------------->WinOLS_(only dpf off - 393893 - Bosch EDC16CP31)_NO CS_DizelDiag.zip<---------------
    test and report
    pass in pm
    good luck
    tell me thanks I will be very happy
    Fec001's Avatar
    Not working, car regen and engine revs up very badly. File is a complete mess.
    Still need a good solution
    HIC's Avatar
    Please post ori file without mod
    Fec001's Avatar
    Here is file without DPF mod
    Jan 2016
    pass by pm
    Sep 2012
    I have the same problem with w164 280cdi. I have tested many solutions and spent lots of time and money to solve this but nothing works. I have reset dpf values with das and also tried the same with launch, dpf temp and differential pressure sensors are disconnected. Original file attached (Read with ktag).
