Results 1 to 11 of 11
    Mar 2017
    Default Corrupted EEPROM on EZS audi
    Hi guys, after trying to read out a pin code with FVDI , same problem as usual, car lost all power , no ignition anymore and no com with module 5 EZS. Tried pulling fuse, reboot with battery off but nothing. I removed the module from the car , read the MCU flash + eeprom with XPROG . Flash seems to be OK, but eeprom seems to be corrupted !? Even the VIN isn't complete when opening the dump as if some bytes have changed ? I've seen a topic on this forum where in the eeprom bytes have been swapped around ... It isn't really my case but something happened ...
    Car VIN : WAU ZZZ 4F97N001643
    Any pros about this topic that could give me a hand on this ?
    I've posted my flash + eeprom read out with XPROG.
    have a nice day !
    Hungary
    Hi !
    Try other older flash under sw130. I think your is above sw180
    Mar 2017
    my flash is SW 2.10 ! you think this can change something ?? when i post eeprom dump on tag key tool with FVDI, it isn't recognized ...
    Hungary
    I was same problem, after change flash car started again.
  5. The Following User Says Thank You to jaromib For This Useful Post:
    bauvaisis (30th June, 2019)
    Hungary
    https://www.digital-kaos.co.uk/forum...50#post3305850
  7. The Following User Says Thank You to jaromib For This Useful Post:
  8. #6
    Mar 2017
    thanks for your answer ! I have exactly same HW, SW and MCU mask as you ! do you still have the flash you used ??? thanks
  9. #7
    Mar 2017
    i opened your eep with TAG tool , and i can read 3 keys programmed , but my EEP is corrupted! i will start by solving this first
  10. #8
    Mar 2017
    or if anyone can calculate checksums on this kind of MCU internal EEPROM ? because i can do the rest manually : keys, pin, VIN etc thanks
  11. #9
    Sep 2016
    There is no cks. Follow advices from jaromib.
  12. The Following User Says Thank You to qeso705 For This Useful Post:
  13. #10
    Mar 2017
    hi guys, just for an update, i managed to get the car working again thanks to Bobble's precious help eeprom and flash were corrupted. But now car is in component protection mode. Got to find a solution ! thanks I saw that ODIS online car do this, but it will be tricky to find someone with access .
  14. #11
    p1et's Avatar
    Oct 2013
    Never touch Audi A6 C6 / Q7 with FVDI
