hello guys,
but I did not understand why the file is 15mb.
How can I write a file of 15m on a pic 18f242?
what should be the size of the file correct?
open it with willem program
save as hex and now it is correct filsize 45Kb
now you have some bytes in the buffer for program and some bytes for data
Thank friends,
you cheked this dump work good?
no not checked
maybe is not working !!
an i have no info for settings "Oscilator" "Watchdog" "Power up timer" ore someting else.
ciao elvis,
How do I know how to set the programmer?
I use Wellon VP980.
MAYBE THIS IS CORRECT.
PIC18F242 configuration settings must be correct, if the wrong program can not run.
We can also test the hex file with the simulator software from the manufacturer.
dlaskarb (25th June, 2013)
ciao,
you cheked this dump? work?
not tested, example configuration bits only
hello guys,
as I do with MPLAB to simulate the various settings of protection?
I need to know what kind of setting should I use to program PIC18F242.
Thanks for dump, can someone have a scheme for this **.BIN file??
Note, that you also need to change the serial number hash in three eeproms. It's not easy to calculate the new hash...
Share with us your experience and we can solve our problem.
Best regards
Dejan
he want the mony to baying pic and 3 eprom
i promess you to open other new beeprog i will try to read this chut pic to solve the problem and then i post result free for all
Hi there,
you have to change the PIC and three serial EEPROMs (they hold the serial number). I can send you all the preprogrammed chips, but charge USD150 for it, because I've paid USD1000 for PIC code extraction and I'd like to get some money back. Sorry for that, hope you understand. After you replace all the ICs, you can use the programmer with the latest ELNEC software without any problem and also upcoming updates will work fine...
Let me know, what you think.
Cheers,
Peter.
