Page 6 of 11 FirstFirst 1234567891011 LastLast
Results 76 to 90 of 152
  1. #76
    Tested working all you need.
    I have the same problem a few months agao and didnt get any replys but now it is me giving the soloution.
    Enjoy.
    PS i know where to come when i have a problem knowing ive helped soooo many people fix their programmer
  2. The Following 8 Users Say Thank You to bellautos For This Useful Post:
    ampibali (18th November, 2015), bmc (25th March, 2020), clauberty (28th March, 2015), darkshiningg (25th September, 2018), florinyes (29th November, 2019), mdanilo (17th April, 2016), PETERALC506 (5th January, 2020), tmaa36 (29th September, 2019)
  3. #77
    page 1 & 3 not change.
  4. The Following User Says Thank You to bellautos For This Useful Post:
  5. #78
    Turkmenistan
    Default beeprog
    Hi all.
    I used this configuration for beeprog. At connection programmer there is mistake EC: 19. Where I was mistaken?
    Thank for answer.
  6. #79
    DK Veteran badisan's Avatar
    Default BeeDump
    Hi all, I also try both configuration, but the same error.
    May be oscillator is wrong. Is oscillator type correct?
    Best regards,
  7. #80
    morocco/fbs
    same problem
    i programme pic with labtool same as picture fuse
    not solved
    help
  8. #81
    Default beeprog 2.67
    Quote Originally Posted by bellautos View Post
    Enjoy.
    can you help me with a link with software kit for 2.67. i have 2.61 and can't find updates for 2.67
  9. #82
    tehnosoftex's Avatar
    Romania
    Quote Originally Posted by jokersat View Post
    same problem
    not solved
    help
    Did you program also the eeprom memory. You can find it at the end of the dump, the last 256 bytes. Labtool will not import the eeprom and you will need to enter by hand.
  10. #83
    morocco/fbs
    yes here is : xxxx6904xxxxxxxxxxxxxx37223BDB70
    yes my friend 3 eprom 900 901 902 + pic 18f242
    where is the problem ?
    i will try to,programe pic with other BEEPROG to Be sure
  11. #84
    Romania
    No that eeproms, I mean eeprom from pic. The pic has also internal eeprom which I noticed it not imported by labtool. Labtool will import only the flash from pic but ignore the internal eeprom. You can see it at the end of the pic dump. the last 256 bytes.
  12. #85
    morocco/fbs
    i think now is good pls see here on picture
    want to test if is good
    test fail , i think on config bit have mistake ?
  13. The Following User Says Thank You to jokersat For This Useful Post:
  14. #86
    abu deab's Avatar
    Quote Originally Posted by gopelhu View Post
    Hi all again,
    Please select the Download section / Car Dumps Database.
    You can download it here.
    My Beeprog was locked and this solution is my solution and tested it and works 100%.
    Regards,G
    Please help I peeprog programming pic18f242 + 3ep but is now operating on Alaeprom only and does not do any programming or Flash Wizard Please help Dumb pic systems
  15. #87
    Romania
    But I think the eeprom must look like this
  16. The Following User Says Thank You to tehnosoftex For This Useful Post:
    tmaa36 (26th September, 2019)
  17. #88
    Romania
    The dump from bellautos is ok. Tested today myself on a wrecked beeprog from a friend and I manage to repair it. I use microchip icd2 for programing, and the config from picture are wrong
  18. #89
    morocco/fbs
    My Beeprog work fine now thanks for all
    OFFFFFFFFFF
  19. #90
    Jan 2009
    CLONE programmer china SAFE ver. ELNEC Software 2.67c 03/2010 =52580 devices tested all ok
    www.megaupload.com/?d=TRB151EX
  20. The Following User Says Thank You to cumelsk For This Useful Post:
