Based on the software number it has.
Hello
Can someone check if this golf 6 2.0tdi 110hp have antichiptuning protection?
Thank you
EDC17CP14
SW: 1037564026
SW upg.: 03L906022LF 9978
Installation: R4 2.0l TDI canvag - int flash
I am asking because clone KTag cannot remove it as far as I have experience with golf 6 so I don't need to dissassemble everything.
MartinF1 (2nd July, 2019)
before 2009 not have tprot ,after 2009 have tprot
Proffesional ECU & TCU Tuning
Petrol and Diesel Engines
File Service
check the date of production car
year day and month
File Service
It is not 100% but as general rule, 10373xxxxx normally not TPROT, 10375xxxxx you cannot trust, most probably TPROT.
The way to be 100% sure is open bootmode read in hex editor and search for string "TPROT"
Depends on the machine you are using..
For example CMD and Kess don't make some older versions by obd, even with no TP..
(Talking about genuine devices only.)
But CMD updated that in they latest releases (forgotten cars).
"VAG edc17/med17 tp2.0 full obd ( also TProtected one ) VR/W/CHK/Recovery"
It does not matter. Use protocol 501, make VR, write Tuning over OBD. File is available on VR Server.
Job done in15 minutes
No wish. P501 takes care about that and makes full write with patch in first block. Like on CP20, CP44, C46, C64, C74. All those work fine.
the best idea is, download software from ECU by OBD2, check SW and CALIBRATION UPDATE, next encrypted the same SW and CALIBRATION SGO or FRF to normal bin. file and find what TPROT you have
you will know all what you need. that is the true
CHIPTUNING, ECO-TUNNG CARS TRUCKS BIKES,
EGR OFF, DPF OFF, NOX O2 KAT OFF, SWIRL FLAPS OFF, THROTTLE OFF, MAF OFF
DTC OFF, LIMP HOME MODE OFF!!!
ADBLUE OFF, SCR OFF, ADDITIVE OFF, CNG OFF, SPEED LIMTER ON/OFF/SET
HOT/COLD START
CRC FIX - FULL GENUINE WINOLS FULL CRC / SWIFTEC FULL CRC
TRANSLATE DAMOS ENG
COUNTER FIX - VAG EDC16, EDC17
ORYGINAL FILES DATA BASE
START/STOP ON/OFF
HOT/COLD START
TRANSLATE DAMOS ENG
START/STOP ON/OFF
