Also check with signal detector if coil is putting out signal to key
Could be bad ignition switch(electrical)
Hello All
Get asked to do a lot of these usual story battery went flat then car won’t start with immo light flashing. Keys won’t program back in so I assume it’s a module reset.
Is there a reset procedure similar to Corsa D or is it a lot more complicated?
What software can reset these ?
Thanks in advance 👍🏻👍🏻
well known problem on hondas after flat battery no start
launch x431 will synch pcm<>immo also relearn keys car will start in 10 min
X100 skp900 x300 launch diagnostics tools all also autel diagnostics tools will do that within 2 minutes
with any tool go to IMMO section and and do Ecm/Pcm sync/matching/reset
Thanks for replying everyone 😊
Usman have SKP900 and xtool pad 2 I’ll try these next time get a call about one 👍🏻
I just had an 04 Accord today
Looks like the transmitter is weak??
I had to glue the chip onto the side of the immo ring to get started
Was working key last week
Now green flashing
Take out chip and put on top of transceiver and see if it fixes it
I checked to see if chip problem but had no problem reading it at a distance with vvdi key tool
So transceiver issue methinks......
Jimmy07 (4th July, 2019)
Thanks Sleeprz
Seems like immo coil on these are problematic next one I get I’ll test them if no joy do a reset 👍🏻👍🏻
