I flashed my AFS module
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 E HW: 7L6 907 357 C
Component: AFS-ECU H04 0105
Revision: -------- Serial number: --------------
Coding: 029600000B000200
Shop #: WSC 73430 115 00052
with
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Coding: 0000000000000000
Shop #: WSC 00000 000 00000
5 Faults Found:
10490624 - No End-of-Line Programming
B2013 00 [137] - -
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 1
Fault Frequency: 1
Reset counter: 71
Mileage: 130102 km
Date: 2019.07.03
Time: 21:16:22
13636352 - Control module not coded
U1013 00 [137] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 71
Mileage: 130102 km
Date: 2019.07.03
Time: 21:16:22
5276144 - Power Output Module for Left Headlamp
C1081 F0 [009] - Not Coded
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 71
Mileage: 130102 km
Date: 2019.07.03
Time: 21:16:22
5276400 - Power Output Module for Right Headlamp
C1082 F0 [009] - Not Coded
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 71
Mileage: 130102 km
Date: 2019.07.03
Time: 21:16:22
5275220 - Headlight
C107E 54 [137] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 71
Mileage: 130102 km
Date: 2019.07.03
Time: 21:16:22
It is not allowing me to code, gives Error 22: Conditions not correct or request sequence error.
I read I will need Parameter file to code.
Please help me with correct procedure and Parameter file for for 5M0907357F VW Passat B7
