Results 1 to 5 of 5
    Jul 2018
    Default Checksum Buffer Error Kess V2
    Hello, i try to write modificated map on edc16u1, and i received checksum buffer error, tool is kess v2 v2.47 5.017.
    I have windows 10 64bit, i tried with windows 7 64bit and same error... i installed, c++ 2005 2008 2010 and netframework.
    nici's Avatar
    Apr 2017
    Use 2.23 Software for 5.017 Device. If You dont have, tell me.
    Jul 2018
    you are sure working with 2.23 on windows 10 ?
    Quote Originally Posted by jxv View Post
    Works, u can use win7 or 8 combatibility
    UK
    I've encountered this issue recently on a similar Bosch ECU using with Kess 5.017 using both 2.47 and 2.25.
    The solution for me was to read the current data from the ECU then, using a HEX editor or similar, to clone the current checksum to the modified file. Both locations of the file checksum should be cloned.
    Then the write was successful with no errors running on Windows 10 x64.
