Results 1 to 3 of 3
Thread: Ktag won't work
    May 2016
    Default Ktag won't work
    can anyone help. bought a new Ktag and won't load protocols can anyone help, don't mind paying, my keys works spot on
    Jun 2013
    EU
    Try opening the ktag, take the sd out and clean its contacts and the pcb sd reader contacts with isopropyl alcohol. Then refit the sd in the pcb sd reader and try again if all ok in software. If not ok you’d better trash the chinese sd card and put a brand new on it.
    Inquizit0r's Avatar
    Aug 2013
    Ukraine
    If this don't help you then bleed your ktag with isopropyl alcohol and burn. And buy another one.
  4. The Following User Says Thank You to Inquizit0r For This Useful Post:
    stabiel (9th July, 2019)
