    Jul 2019
    Default corsa d (diesel) pin code help please
    hi, i need the pin code for the lads car, a corsa d 1.3cdti (diesel) so i can use opcom to add another key. the code on the car pass is wrong as it has had a replacement ecu in the past. also the radio / display have been upgraded previously so i wouldnt trust them to have the correct pass either. im trying to do it 'on the cheap' as the lad has spend every penny he has buying the car and i have had to spend a FORTUNE to get him insured too. so what is the easiest / cheapest method of getting the pin please? i looked at getting a cheap mpps v16 from ebay but i dont know if this would be able to get the data i need from the ecu ? any advice / guidance would be great please.
    stoyanov's Avatar
    42 75 6C 67 61 72 69 61
    Read eeprom from instrument cluster to get pin code.
    Jul 2019
    Quote Originally Posted by stoyanov View Post
    i was hoping to get away without taking the car to pieces and do it via obd if possible
    Nov 2016
    The eeprom dash will be the quickest to read, as Stoyanov mentioned
    Jul 2019
    slight development.... i have been told i can have (borrow) the cd30 radio or the display that was fitted to the same car the ecu came from, would i be able to read the eeprom in that to get the pin?
    Jul 2019
    just in case anyone else needs to know. read pin from radio works fine (providing it is the original radio of course) using a eeprom programmer
